Home > Maintenance & Modifications > Burnt Valves Replacement
tonyg74
United Kingdom 2010 Range Rover Sport Supercharged Autobiography Java Black
Does anyone know a reputable garage/mechanic who can replace burnt valves?
My 2010 RRS S/C has 2 misfiring cylinders. My indy specialist doesn't have the tools to remove the head and suggests I take to the Steamers!
Post #574275 Sat Feb 02 2019 9:16am
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
If you are taking the heads off it’s probably just as easy to have them fully refurbed. It’s been a LONG time since I did a V8 head gasket (3.9 classic Range Rover!) but removal isn’t an horrific job and most garages should be able to take them off. If your Indy can’t then he either isn’t competent or doesn’t want the job.
Up here in the grim north I’ve always used a company called lockstitch in Rochdale. They always did a good job and would pressure test and skim if necessary, before giving it back looking like new.
Probably worth giving them a call to get a cost to give you a benchmark. As you are in London, you will obviously have to add 200000% to that, in order to pay for someone’s 3 million quid bedsit Laughing
You could probably pallet them up here if the price difference dictates it necessary, just need someone to take them off! (and put them back) Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #574282 Sat Feb 02 2019 10:30am
hpw do you know it needs valves? Shocked
Have 2 coils been changed? or swapped with ones from good cylinders ?
Post #574283 Sat Feb 02 2019 10:34am
hoppy_70
Ready done and refurbished heads are £850 each on eBay but I reckon the above firm would be much less doing your own (rather than on an exchange basis) Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Post #574284 Sat Feb 02 2019 10:35am
tonyg74
2million for a bedsit now...Brexit's fault!
I agree, I think my Indy doesn't want the job. Will ring around and get quotes.
Thanks
Post #574298 Sat Feb 02 2019 11:20am
Disco_Mikey
5.0 is becoming pretty common for faulty injectors...
And/or worn chains and guides...
Both if which would cause a mis fire
Post #574307 Sat Feb 02 2019 12:27pm
