Home > Faults & Fixes > 3.6 tdv8 non starter help please |
I would have expected the high pressure pump to just expel the air by that point, I assume the injectors went back in the same positions? Have you pulled one out again, put it in a container (if you can) and turned it over to see if you get any mist? ( got to be real careful if you do that) 2012 5.0 SC AB
Sun Jan 20 2019 9:24am |
