Home > Technical > Indicator |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
Are you sure it's the full beam? It is more likely to be the cornering light (it has a separate bulb in the headlight unit) 2016 Black SDV8 Autobiography
Mon Dec 24 2018 11:28am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
there's a bulb in the reflector below the indicator
Mon Dec 24 2018 11:30am |
Tomascole1 Member Since: 26 Jul 2018 Location: Gwent Posts: 104 |
No it's definetly full beam I have the blue full beam light appear on the dash |
Mon Dec 24 2018 11:31am |
probably faulting indicator stalk then as an easy and cheap attempt to fix |
Mon Dec 24 2018 12:17pm |
Does the full beam come on with the Baz lights? If not I’d go with stalk to. 2012 5.0 SC AB
Mon Dec 24 2018 9:24pm |
The with baz? |
Mon Dec 24 2018 10:36pm |
Bloody auto correct.... Hazard lights 2012 5.0 SC AB
Mon Dec 24 2018 10:48pm |
No just indicating left it's strange |
Mon Dec 24 2018 11:00pm |
How hard is it to change an indicator stalk?? |
Before you do look at changing that, maybe try disconnecting the left front indicator and see if the full beam comes on still, then repeat with the rear and then the door repeater just to rule out a bad earth (although I suspect only the front left if any, would effect full beam).
Tue Dec 25 2018 12:41am |
It's strange because when I put full beam on it doesn't seen to click on if you know what I mean is it supposed to? Merry Xmas to all by the way |
Tue Dec 25 2018 9:13am |
well if the stalk doesn't feel right, and indent onto main beam, that is a good reason to change it |
Tue Dec 25 2018 12:11pm |
So there's supposed to be an indent into it?? |
Tue Dec 25 2018 12:16pm |
your meant to push the stalk back (to the dash board) and it stay there in main beam mode, just like 1970's cars.
Tue Dec 25 2018 12:39pm |
