Home > Technical > External temperature sensor |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
I would say that you should check everything in the area that he has been working, which will be across the front panel under the bonnet, and also the wiring loom across the rear of the engine. It has to be moved to access the fuel pump drive belt. Check that all the loom connections are pushed together properly. |
Fri Dec 21 2018 5:07pm |
Fri Dec 21 2018 5:08pm |
Diesel77 Member Since: 08 Jan 2014 Location: East Posts: 3 |
Thanks , ill do that.I don't know if it's that but after clearing the errors , the temperature went back to normal. |
Fri Dec 21 2018 7:07pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4876 |
Sun Dec 23 2018 10:34am |
