Home > General (L494) > Speedo correct?
Cornishman
Speedo correct?
When driving on the dual carrageway at an indicated 70 mph along with everyone else, we all do down here , of course, !! I always seem to be traveling 1 or 2 mph more, is my speedo correct, as I’m running 22inch tyres. Good question for Tyrefitter perhaps?
Post #570413 Tue Dec 04 2018 12:49pm
rangiejools
Australia
All tyres fitted to an RRS are the same diameter whether on 22 inch wheels, 21s or 20s. The speedo on an RRS is about 4-5% optimistic. For instance when I see 105kph on my speedo I am actually doing 100kph. SDV8 arrived and fantastic even the infotainment!
1983 2 door Range Rover ARB Bar X9000 winch ARB Rear Bar now semi retired.
Many big trips done in this one.
1982 Rangerover nearly restored.
22 Defender D250 with lots of stuff for outback touring
Nice 2013 Freelander TD4 manual (for daughter to learn on) with much better stereo compared with previous SD4 SE with Meridian which sounded bad!
2013 Land Rover Defender ute.
Post #570414 Tue Dec 04 2018 12:55pm
Tim in Scotland
There is a 10% high margin of error permitted on uncalibrated speedos so at 70 speed limit you can be up to + 7 mph out. You can get an indication of errors using a phone app route guidance program online for your phone - one that shows your speed and you can compare the readings. Don’t use the in car nav system as it is an average not an instant reading
Post corrected to remove the -% 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #570415 Tue Dec 04 2018 12:55pm
kmpowell
As Tim says, ff you download a GPS speedo app you will get a better picture of your actual speed. On mine 74mph is 70mph. 95mph is 89mph (tested on a private road of course). SOLD - MY16 SDV6 Autobiography Dynamic - Fire Engine Red, Fixed contrast pan roof, TV, Dual Screen, 5+2, Privacy, Noble paddles.
Post #570416 Tue Dec 04 2018 1:19pm
Lindab
I have a Road Angel in my car which is GPS based. At 70mph on Road Angel the RRS speedo is showing 74. I never look at the car speedo now, always Road Angel. Only downfall of Road Angel is it is not bright enough especially on a sunny day. I emailled them about it, but no reply although they are quick enough to phone you when the subscription is coming up for renewal.
Post #570419 Tue Dec 04 2018 1:38pm
00by
Tim in Scotland wrote:
There is a 10% margin of error permitted on uncalibrated speedos so at 70 speed limit you can be +/- 7 mph out. You can get an indication of errors using a phone app route guidance program online for your phone - one that shows your speed and you can compare the readings. Don’t use the in car nav system as it is an average not an instant reading
You're right on the 10% margin of error, however it is only in one direction - your speedo can read up to 10% too high but cannot read lower than your actual speed. (Well, it obviously can technically, but not legally.) MY16 RRS 3.0 SDV6 HSE Dynamic
Post #570425 Tue Dec 04 2018 3:17pm
Cornishman
Speedo correct?
Thanks for all the info, will get the app, will be interesting.
Post #570431 Tue Dec 04 2018 5:49pm
Tyrefitter
Is yours a RRS1 or 2 & what size 22’s are you running.? But as everyone says speedos are always set under the actual speed you are doing,I’m running 295/40r22’s the same as they fit on the svr’s with 22’s & mine is more accurate to the Satnav than it was with the 275’s. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #570432 Tue Dec 04 2018 6:20pm
Cornishman
Speedo correct?
Sorry Tyrefitter, it’s a my16 hse 306, still running original continentals cross contact lx 275R40 x22
Post #570456 Tue Dec 04 2018 9:22pm
Oldandconfused
As far as I'm aware, the accuracy of speedometers is governed by EU directive and must not under-read, and can over-read by up to 10%. I use a sat nav, I have a Garmin, the wife used a TomTom. Give it a try and compare it to your speedo so you know where you stand..
Post #570484 Wed Dec 05 2018 10:04am
PIG88
Speedometer 55 Pro is a good app for checking your speed. It also has a feature which reverses the figures and gives you a speed head up display on the windscreen if you put your phone on the dashboard.
 Current: 2020 P400e HSE Dynamic
Gone: 2016 SDV6 HSE
2012 SDV6 SE
Post #570502 Wed Dec 05 2018 6:09pm
