Home > Maintenance & Modifications > Service (Additional Oil)
Lindab
Every time my Range Rover Sport comes back from a service (5 year service plan) they leave a 0ne litre bottle of Mobil 1 in the footwell for top up. My car luckily does not use any oil between services. My F type Jaguar however does not get a (free?) bottle
Post #569520 Fri Nov 23 2018 10:09am
Black Bess
So every 5 years the Jag gets a free oil change ?!? Very Happy
Post #569521 Fri Nov 23 2018 10:32am
Lindab
Looks like it, as I now have 3 bottles Whistle Or when the service plan ends I can say to them I shall supply my own oil. Rolling with laughter
Post #569522 Fri Nov 23 2018 10:42am
Ford do this too (or certainly did)
It's a good hit to modern drivers that you are actually meant to check the level between services!
and you will always have oil to hand of the same spec to use if topup required
Post #569535 Fri Nov 23 2018 1:27pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Is Mobil 1 a C1 oil that meets the Land Rover spec?
Post #569555 Fri Nov 23 2018 6:48pm
Mobil 1 is a brand. There are many variants
Post #569556 Fri Nov 23 2018 7:19pm
Lindab
It must meet their spec as its them who put it in my car
Post #569557 Fri Nov 23 2018 7:33pm
LandPhil
You haven’t filled in your car details in your profile so we don’t know what RRS model you are driving.
BUT, if you are driving a 3.0 diesel with DPF the oil must meet this spec.
5W 30 Fully Synthetic C1 WWS M2C934 -B
If that is not on your free bottle it ain’t the right oil.
Hope it is.
Post #569567 Fri Nov 23 2018 9:56pm
LandPhil
I can’t find a 5W 30 C1 , they do C2 but that is the wrong oil
Post #569568 Fri Nov 23 2018 10:02pm
I thought C3 superseded C1, but could be wrong
Post #569612 Sat Nov 24 2018 11:10am
Lindab
My profile wont allow me to put in anything newer than year 2013 I have a 2015 Range rover sport HSE diesel & although the main dealers get a bad rep, I imagine they know what grade of oil to put in.
Post #569623 Sat Nov 24 2018 1:30pm
LandPhil
I admire your confidence and I hope it is not misplaced. My experience was taking my Freelander 2 in of its first service and when I was presented with the invoice it said they had put in an A5 oil. I queried this and they said it was just a computer mistake printing the invoice. At that time Freelander2s were having regular DPF problems some of which were attributed to using the wrong oil. I insisted they drain my car and put in the correct grade as speced. They were not happy but did it.
Andy K - C3 can be used if C1 is not available but must be changed more frequently. I have never heard of C2 being used.
With the crank issues this engine has I would want proof the right oil is in it.
Post #569627 Sat Nov 24 2018 1:57pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
C2 is for DPF cars allowed if C1 difficult to find. See the LR owners manual.
The difference between C1 and C2 oils is the ash content. C1 max 0.5, C2 max 0.8 (see ACEA )
I studied the different oil technical specs in dept and came to the conclusion that 5W30 Mobil 1 ESP , a C2/C3 qualification, is probably the best oil for the 3.0 TDV6 DPF. Why?
Because the ash content is not more than 0.6, so almost a C1, but it also meets C3, which means a stronger oil film than C1. This is preferable with an eye to the crankshaft failures. Mobil also has in comparison a very high boiling point (240), wich says someting about the synthetic quality of this oil (ester content) and a relative strongTBN (7.0) which means that it provides high cleaning capabilities.
IMO Mobil 1 ESP out performes Castrol Edge and most other C1 oils. And, no, I have no connections to Mobil. RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #569670 Sat Nov 24 2018 11:56pm
Tyrefitter
Good bit of advice their Hog.i might look into Mobil oil for our my15 Evoque as it due a service & mot in the next week or so,we only do about 3000 miles a year in it & it’s mainly local runs but touch wood we’ve had no problems with it in the 2.5 years we’ve had it,,the mileage is about 18500 now.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #569681 Sun Nov 25 2018 9:48am
Tim in Scotland
Andy, is your Evoque a 2.2 SD4 or a 2.0 Ingenium motor - the Ford based 2.2 doesn’t seem to suffer the oil dilution issue to the same extent as either the SDv6 or the Ingenium engines. Over on BabyRR.com we have had next to no reports of early services being required due to oil dilution on either the Ford or the Ingenium engines 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #569702 Sun Nov 25 2018 1:59pm
