Home > General > 2011 tdv6 won't start trying to crank and dies. |
You'll pay way more than 3k for an engine supplied and fitted. Really hope it isn't that. 2 new turbos supplied and fitted was near 4k at an indy specialist, never mind main dealer. |
Mon Oct 22 2018 10:44pm |
newlove2003 Member Since: 16 Apr 2015 Location: west yorkshire Posts: 24 |
Hiya the video is here any help would be great also just cleared all the faults and the diesel a control, code P0627
Sat Oct 27 2018 1:53pm |
Fuel pump issue, at least it not the crank.
Sat Oct 27 2018 2:36pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4347 |
Agreed, its a fuelling issue.
Sat Oct 27 2018 2:49pm |
Thanks for the speedy reply, feel like a ton as been lifted off of me, independent range rover speacialst scared the living out of me saying new engines etc, how could they miss this issue. Got a freind coming up tomorrow who is a mechanic at Merc, the car as not been serviced for quite a bit and he said he will start with that. Any pointers what he should start with first and then what ever next thank you |
Sat Oct 27 2018 3:36pm |
If it’s not been serviced in a long time, download the check sheet from topix (there maybe a copy on the site in someone’s profile) and ask him to perform all the checks and fluid changes. Also ask him to check the fuel pump relay and if he can, check for fuel pressure from the pump. I suspect you may need a new pump and relay. 2012 5.0 SC AB
Sat Oct 27 2018 4:07pm |
Will do thank you, well my mate couldn't make it he had to do somthing with his bird, so I've had a little look and seen 2 videos on changing the fuel filter doesn't look hard at all, looks very simple would to be possible that I could do this myself? Also could it be possible the reason it ain't working is down to the wiring on the fuel filter? Thank you. |
Sun Oct 28 2018 2:59pm |
I don’t think the filter will have any wiring but it would be worth replacing if it hasn’t been serviced in a long time. If you mean fuel pump, I think there may be 2, one in the tank and one else where. The one in the tank is bound to be a PITA, because of where it is and how to get to it.
Sun Oct 28 2018 3:28pm |
paulwest16 Member Since: 19 Feb 2023 Location: Essex Posts: 5 |
Did you ever solve this problem and if so what was the outcome.
Mon Feb 20 2023 5:32pm |
RR-Panda Member Since: 01 Aug 2023 Location: Gold Coast Posts: 6 |
@paulwest16
Tue Aug 01 2023 6:00am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4872 |
The original post is 5 years old, I think it unlikely you will get a response now from the O.P, but you may be lucky.
Tue Aug 01 2023 6:22am |
Mine was the chain on the inlet on the passenger side broke. It a small chain that does the inlet cam not the main one that goes to the crank that’s why the engine was spinning ok still. |
Tue Aug 01 2023 7:15am |
Hi Paul, thanks so much for your reply. I suppose a broken cam chain is better than a broken crank!!
Tue Aug 01 2023 7:22am |
Thanks Col |
Tue Aug 01 2023 7:55am |
