Home > Technical > Drivers side rear Suspension One inch higher than all others |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8848 |
It's not unusual for one corner to be out, sadly. If the tyres are wearing evenly and there are no errors or issues, I wouldn't worry about it too much.
Fri Oct 26 2018 9:08pm |
IOMMAN Member Since: 26 Aug 2018 Location: Peel Posts: 13 |
My 2006 RRS was low on the NSR and was giving cross articulation faults and lowering to the bump stops + going into extended mode when selecting access height
Fri Oct 26 2018 10:18pm |
SlyBacon Member Since: 24 Oct 2018 Location: Dorset Posts: 22 |
Oh dear thanks for the replies, I guess i shall live with it.
Sun Oct 28 2018 4:44pm |
Suspension all recalibrated today by our dealer and it’s all level again - OSR was low Current
Mon Nov 12 2018 10:12pm |
Srg70 Member Since: 09 Sep 2017 Location: Surrey Posts: 16 |
I have recently had/have the same problem, ns is fine, os is about an inch higher. when i try and lower to access height it goes into extension mode and raises back up. Had an independant land rover mechanic diagnose it and no faults codes came up. He suggested that we could start with repakcing the height sensors but no g'tee that was the fault. Dont want to pay for new parts if its not the cause of the problem. Any ideas ? 2015 RRS SDV6 HSE Grey |
Tue Nov 20 2018 4:15pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
need to have it calibrated |
Tue Nov 20 2018 8:13pm |
