Home > Technical > Hunter Wheel Alignment
Page 1 of 3 123>
amgmaj
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi everyone
Need some advice regarding my RRS Hunter Wheel Alignment had this done today as the RRS was pulling towards the left when steering wheel is straight but when the lad who was doing the Wheel Alignment could not find the settings on his Hunter machine for the 2010 Range Rover Sport 3.0 tdv6 L320 so went by doing it on the Range Rover 5.0 SC settings is that right???
Plus the RRS is still pulling towards the left like before if not more so now and steering wheel still not straight more like (12.30pm)
I've got it booked in again tomorrow morning so any advice will be appreciated.
Some pictures of before and afterwards if that helps
Thank you
Post #567683 Fri Oct 26 2018 4:57pm
There should be caster readings too, for a start. Looks like some inexperience from the operator perhaps. 2012 SDV6 - it's missing a couple of cylinders
Post #567684 Fri Oct 26 2018 5:11pm
amgmaj
I thought the caster readings are there in Grey ink I could be wrong though...
Post #567686 Fri Oct 26 2018 5:15pm
Tyrefitter
I would have thought the settings are the same for diesel & petrol.All the readings are in the green but does the guy who did it have the car in the right mode for the alignment.?
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #567690 Fri Oct 26 2018 5:49pm
amgmaj
If you mean TTM yes I did that my self iid tool...
Post #567691 Fri Oct 26 2018 5:57pm
Tyrefitter
Were all the tyre pressures the same before he started.?That can make a difference.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #567692 Fri Oct 26 2018 6:02pm
Brit Plumber
Re: Hunter Wheel Alignment
Well according to the printouts you’ve attached he’s used the L320 5.0 Normally aspirated and Diesal non active ARB settings. So if yours has dynamic response then it is incorrect. It’s also not what he’s told he’s used. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #567694 Fri Oct 26 2018 6:50pm
Tyrefitter
I thought all post 2010 were supercharged.it could be the data on the machine is wrong,I used to have the computerised aligner & sometimes it didn’t have the right info for the model/ year for car I was doing.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #567695 Fri Oct 26 2018 6:56pm
amgmaj
Andy
To be honest me or the guy didn't check the tyre pressures will do that tomorrow before take it back again...
Post #567696 Fri Oct 26 2018 6:59pm
Tyrefitter
I meant all the pressures set to right pressure not all the same Wink
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #567697 Fri Oct 26 2018 7:05pm
amgmaj
How can I tell if my RRS 3.0TDV6 2010 has dynamic response?
Which settings should go for on Hunter machine if he can not find my RRS model and year?
Thanks
Post #567698 Fri Oct 26 2018 7:06pm
Tyrefitter
Dynamic response is on a rocker switch near suspension settings,it should come up on dash with dynamic when activated iirc
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #567699 Fri Oct 26 2018 7:11pm
amgmaj
Andy.
Laughing Will check that also what should tyre pressure be on 22" wheels with 285/35 tyres?
Thanks
Post #567700 Fri Oct 26 2018 7:11pm
Tyrefitter
I would put fronts to 36 & rears to 38psi.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #567701 Fri Oct 26 2018 7:13pm
amgmaj
Thank you for your quick replies guys Thumbs Up
One more question which settings should go for on Hunter machine if he can not find my RRS model and year?
Post #567702 Fri Oct 26 2018 7:17pm
Page 1 of 3 123>
