Home > General > Non OEM brakes & Extended Warranty
hafman
I am about to take out an extended warranty with JLR as my L494 is coming up to 3 years old.
I need to replace all four brakes & pads etc. The main dealer want £1,500 for the work.
A local specialist wants either ~£600 if they fit non-OEM parts, or ~£1,200 for OEM.
Question: if I fit the non-OEM what effect will that have on the warranty? Will I end up having all or any (non brake) warranty claims rejected or I am OK to go ahead and fit the cheaper parts?
TIA
Post #566442 Mon Oct 08 2018 8:49am
Lindab
Ask the main dealer the question. This is not for someone else to have a guess at. Also check what is covered as the extended warranty is not the same as the manufacturers warranty. Some things are not covered.
Post #566444 Mon Oct 08 2018 9:05am
hafman
All the dealer will say is "all claims will be rejected" as they will want the business; I was hoping others may have been in a similar situation before & I might benefit from their experiences.
Post #566447 Mon Oct 08 2018 9:21am
Would have thought it highly unlikely discs and pads would be covered under warranty anyway as these would be considered wear and tear items, mind you L/R might use it as a excuse if there was a problem with another part of the brake system.
Post #566449 Mon Oct 08 2018 9:43am
Lindab
Looks like you have your answer "all claims will be rejected" after all, its them who you will have to take the car back to for warranty
Post #566451 Mon Oct 08 2018 9:55am
Does it really need new discs! What mileage has it done?
Post #566464 Mon Oct 08 2018 12:02pm
hafman
44,000 miles; I have just checked the discs and all four have a lip on the outer edge - perhaps 1-2mm - so presume they do need changing.
Post #566473 Mon Oct 08 2018 1:01pm
It won't affect the warranty because brake pads and dsics are covered by it anyway. The calipers are but the make of pad / disc won't affect these anyway. 2012 SDV6 - it's missing a couple of cylinders
Post #566495 Mon Oct 08 2018 6:01pm
