Home > Technical > Suspension calibration problem
walyhst
Can anyone help me, I had rear passenger corner sagging a little so purchased a gap iid to diagnose the issue turns out it was the height sensor so I have replaced the sensor and tried to calibrate,it allows me to set all corners to 461mm but when go to save settings it says unable to save fault e50 can anyone shed some light on this
Post #566297 Thu Oct 04 2018 9:37pm
Brit Plumber
Should the rear not be 465mm, fronts 461mm?
Have you done physical measurements from wheel centre to top of wheel arch? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #566303 Thu Oct 04 2018 10:48pm
walyhst
Thanks for the reply, the iid tool says 461mm all way round, would 4mm make it not save settings? Im measuring from the centre of the hub to the wheel arch lip, Another thing not sure of but on a few posts on various forums it mentions the car needs to be in tight tolerance mode from what I understand it's done by removing the eas relay but just going off the guided calibration on the iid tool nothing is mentioned about tight tolerance mode
Post #566304 Thu Oct 04 2018 11:07pm
Brit Plumber
No I don’t think tight tolerance mode is needed.
This is what I was going from.
 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #566305 Thu Oct 04 2018 11:13pm
Might well be wrong here but if you have removed a EAS relay have you not in effect disabled the eas, so how is it able to know what you are trying to do as it will not be able to do anything. I think the tight tolerance mode is used primarily for 4 wheel alignment not suspension calibration. There are a lot of member on here who have done the calibration and I'm sure one will be along shortly to tell you where you may be going wrong.
Post #566307 Fri Oct 05 2018 1:29am
walyhst
That's exactly what I thought col, maybe disabling the eas you can set the height baseline so it can't move the height itself to what ever the car thinks is level,yeh hopefully someone can help as I don't fancy RR dealer prices for labour
Post #566316 Fri Oct 05 2018 10:28am
I can't see anything in the Gap Users Manual about removing the eas relay during calibration, but did see this.
CAUTION
The tight tolerance mode should only be used when a wheel alignment
is performed. Leaving the EAS ECU permanently in this mode
can lead to premature failing of components.
Post #566318 Fri Oct 05 2018 11:30am
