Home > Technical > Towbar Electrics |
Yes just plug in behind bumper on passenger side rear,but it’s a bit fiddly
Tue Sep 25 2018 6:25pm |
I bought the 2010 kit as it was the same price as the 2012 kit and just used the trailer harness’ and sold on the 2010 parts. There are blanks (non pinned male connectors) on the female connectors which if you can get the pins, would enable the use of bog standard cabling and connectors instead of the expensive LR items. Had I known earlier, that’s what I would have done. 2012 5.0 SC AB
Tue Sep 25 2018 7:08pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4798 |
gstuart on Disco3 knows the connector pin type used I think.
Tue Sep 25 2018 7:35pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
The L/R part number for the 13 pin kit on a MY12 car is VPLST0071 and the N & S one is VPLST0070. At £125.00 bit pricey but might be able to use number to cross reference to pattern part or find wiring diagram.
Tue Sep 25 2018 8:24pm |
I used VPLST0014 which is for the 10 and 11 MY but only used the 12n & 12s looms (which is the same as you get in the VPLST0070 kit) and sold the other bit on.
Tue Sep 25 2018 10:03pm |
There is a sticky in the maintenance section on how to wire up |
Tue Sep 25 2018 10:31pm |
That needs updating to accommodate the 13 pin socket as well.
Tue Sep 25 2018 11:07pm |
gstuart Member Since: 12 Nov 2017 Location: kent Posts: 3 |
Hi
Tue Sep 25 2018 11:47pm |
Thank you |
Wed Sep 26 2018 12:02pm |
Ur welcome
Wed Sep 26 2018 12:27pm |
Thank you |
Wed Sep 26 2018 7:23pm |
