Home > General > 3.6 tdv8 turbo failure.... |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
£3k to supply and fit two new LR turbos is an amazing price when considers that the turbos are about £1400 each...or is that £3k plus VAT i.e £3600. 2012 SDV6 - it's missing a couple of cylinders
Mon Sep 17 2018 5:20pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
FWIW, I charge £3650 Inc VAT for 2x brand new OEM turbos, oil feed pipe, and fresh oil/filter at the same time |
Mon Sep 17 2018 5:49pm |
How many reviews were there? Is it just the one? Is the feedback reputable? Problem with the Inet is anyone can post a review, did this garage just give them selves a good review? If they were that good and that cheap, lots of people would be using them and word would spread quickly. Generally if it’s to good to be true, it generally is. I would be asking how they change the Turbos when every other garage takes the body off. They could for all the customer knows, cut the wings off and weld them back on, I know that’s an over the top remark but you just don’t how they do it when no one else can. 2012 5.0 SC AB
Mon Sep 17 2018 6:05pm |
Tm17 Member Since: 08 Jan 2018 Location: Birmingham Posts: 16 |
https://g.co/kgs/Jw4Uff
Mon Sep 17 2018 6:48pm |
They don't take the body off so they can charge you more labour? |
Mon Sep 17 2018 6:49pm |
Aparently it’s more labour intensive than taking the body off ..... |
Mon Sep 17 2018 7:12pm |
....in which case, begs the question as to why do they do it that way ? I did both my turbos on an SDV6 and paid pretty much Disco Mikey's price for body off, drain pipe etc, and had back belt changed as well at a JLR indy specialist. |
Mon Sep 17 2018 9:02pm |
Body off sounds scary but the vehicle is designed to be taken apart. Disco_Mikey even put a run through with pictures on the Disco site. Not difficult for a competent mechanic and allows full and proper access to the turbos. Putting it back together is just a case of being careful and thorough.
Mon Sep 17 2018 9:05pm |
They told me it’s a safer process as only the engine is being touched and won’t affect susepobrakes etc that’s why they do it this way. I will find out some more information from them |
Mon Sep 17 2018 9:22pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
A year or so back, a member of this forum used Best Turbos and was delighted with their service. To that effect, I bookmarked the company website in case I ever have the fault myself. Some searching may find the post.
Mon Sep 17 2018 9:35pm |
The car is designed to come apart easy. Suspension is not affected, and the only issue with the brakes is bleeding them afterwards... |
Mon Sep 17 2018 10:10pm |
Update
Tue Sep 18 2018 1:27pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
No engine oil? how does that happen? Merc C220 estate Sport AMG
Tue Sep 18 2018 3:36pm |
Non-working intercooler? Probably full of oil from the turbo oil seals failing. 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 18 2018 6:01pm |
