Home > Maintenance & Modifications > Megaflush |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
If the fluid was changed 4 years ago just add lube guard.
Wed Sep 12 2018 11:07am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
If it's juddering then the torque converter clutch is already going down hill. A flush won't make it better. A tube of Dr Tranny will help until you get the TC changed. 2012 SDV6 - it's missing a couple of cylinders
Wed Sep 12 2018 4:04pm |
chrisbarr35 Member Since: 26 Aug 2018 Location: Chesterfield Posts: 3 |
Thanks for the advice, makes sense to see how long I can delay replacing the torque converter using Lubeguard and getting the metal sump fitted at the same time as a new TC in the future.
Sun Sep 16 2018 7:02pm |
I wouldn't be hard over on a metal sump. (they are prone to leak, don't always have a drain plug)
Sun Sep 16 2018 9:19pm |
