Home > Technical > is this all battery related? hdc gearbox park brake |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
The easiest quick test is a load test - can be done with headlights & cranking. If the car has a fault and pulling excessive load there may be a 'crack' or visible spark when disconnecting/reconnecting (not the safest test if recently been charging). A clamp ammeter may indicate this but you'd need to have a base load from a good vehicle to compare with, unless it's a big load which then would be obvious.
Tue Sep 11 2018 8:47am |
W18ODY Member Since: 31 Aug 2014 Location: north east Posts: 87 |
cheers for the reply!
Tue Sep 11 2018 8:56am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
You need a new battery anyway. 10.4V is entirely discharged which just about the best way to kill a car battery. I would bet on there being a dead cell in the battery. Replace it now before you your alternator. 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 11 2018 2:41pm |
battery is currently off the car and has been for about 6 hours and is currently sat at 12.6v would this not suggest the probem is something draining the battery rather than the battery itself? dont want to buy a new battery for it just to loose charge down to 10.4v again
Tue Sep 11 2018 2:44pm |
update:
Tue Sep 11 2018 6:27pm |
My thoughts are that dropping from 12.55v to 10.4v just by connecting to the car tells the battery is goosed, it would need to be a high load to pull it down that much on a good battery which I suspect you would definately know about when connecting due to the crack/spark, I wouldn't even expect the engine cranking to pull it that low on a good battery.
Wed Sep 12 2018 8:38am |
cheers insiorc, there was actually a little spark when connecting although im positive there wasnt when i did it the other night. another interesting observation, i pulled the fuse for the rear blowers seen as this seemed to be pulling about 0.3a after switch off, car started fine then after a drive i turned it off went back out about an hour later battery was still at 12.6v and started fine not a single error message (gret! i thought) however after returning home that night i turned the engine off and checked the voltage to see what it was at, the "follow home" lights were on at this point anf the voltage was dropping significantly then when they went out it continued to loose 0.1v a second! down to about 11.8v.
Wed Sep 12 2018 8:50am |
I'd made an assumption all your readings were after a full battery charge using a proper charger, if not then you may have been wasting your time - any suspect battery issue's needs to be checked with a fully charged battery as a car doesn't charge them properly. A good battery will hold voltage with little load drain. a goosed battery will lose voltage with a small drain like what you have been finding. I may well be out of touch with battery maintenance methods as I only know of 2 ways to test a 'fully charged' lead acid battery, a load test or new fangled analyser test. The load test as mentioned earlier is the cheapest and easiest. An analyser probably costs as much or more than a battery (although a garage probably will have one). 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Wed Sep 12 2018 9:04am |
ah unfortunately not they were all after a run which as i've read doesnt quite charge the battery properly.
Wed Sep 12 2018 9:08am |
As a rule of thumb from a flat battery of 12v you divide the battery aH rating by the charge amps, so a 100aH battery takes 10 hours at 10A charge. So your 40 minutes would need a serious charger to charge that quick, in itself probably destroying the battery. It's 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Wed Sep 12 2018 9:33am |
thst was my thoughts, im pretty uneducated with the electrical side of things so thought id best ask.
Wed Sep 12 2018 9:43am |
In my limited experience with batteries, if it’s quick to charge, it’s quick to discharge.
Wed Sep 12 2018 10:06am |
Britplumber that sounds like a pretty good theory to me!
Wed Sep 12 2018 10:13am |
My last battery would charge fine with my Ctek but then would go downhill almost straight away when asked to do anything.
Wed Sep 12 2018 4:11pm |
