Home > General > Help please - work done, now something doesn't look right!
Richythepom
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
I've called the garage today - they don't sound too happy about it but have agreed to take it in again to have a look. Considering I've spent close to £2.5k with them in the past month on the big 10yr service/MOT and subsequent work, I would have thought they'd have been more keen to sort it?!
They also mentioned on the phone that there was a note on the job-sheet about it tearing and repeated that it's just a strip of rubber. Grrrrrr!
Here's a close-up:
 2008 RRS HSE Stornoway Grey
Post #564105 Wed Aug 29 2018 10:23am
As I said they have ripped part of the seal away, it should locate in a groove in filler neck and form a nice tight seal, it is not possible to buy the seal seperate you or they will need to replace the complete part LR014044 which I posted a picture of. If they had done the job correctly they would not have torn it in the first place.
Post #564106 Wed Aug 29 2018 10:36am
Richythepom
Thanks again, Col. I've emailed them the LR part number. Let's hope they don't try and bill me for it and/or the work! 2008 RRS HSE Stornoway Grey
Post #564107 Wed Aug 29 2018 10:45am
Here is a better picture of the seal which is damaged.
Post #564109 Wed Aug 29 2018 11:03am
Richythepom
Dropped my RRS in to the garage today to get the work done/looked at. Was immediately greeted with being told the rubber was old and that these rubber bits perish as they get old and get regularly covered in diesel, so it just split as they were putting it back over the metal filler neck etc. etc.
That's quite likely true, but wouldn't you expect it to be sorted regardless before being handed back to a customer?
I mean - how am I to know whether it's just one of those things (and therefore something I should just hand over another loads of dosh for) or whether they've simply not been careful enough..?!?!
Plus - wouldn't you expect a garage to let the owner know something like this has happened during any work, rather than leave it as a 'surprise' for the owner to find on the next fill-up?!?! 2008 RRS HSE Stornoway Grey
Post #565070 Wed Sep 12 2018 1:46pm
Stevepd
i'd like to think that any decent garage would let you know of anything found along the way Censored 2006 2.7 TDV6 HSE in Cairns Blue.
Post #565073 Wed Sep 12 2018 3:22pm
Richythepom
Well, £170-odd later, I've just picked her up with the seal fixed.
I must admit, I was somewhat surprised and queried the bill, but was fobbed off with the "old seal was old/perished etc." (i.e. not their fault)... safe to say - not terribly impressed considering in the past month, I've forked out over £1k on the 10 year service & MOT plus £1,500 on a wheel bearing, fuel breather tube and tracking with the same garage and it's been returned to me with the seal torn...
Evil or Very Mad Censored
If she's still not sold by the next time, I won't be using that garage again! 2008 RRS HSE Stornoway Grey
Post #565085 Wed Sep 12 2018 5:19pm
geoffsnook
If it was as they say then they should have informed you before handing the car back or asked you if you wanted it replaced as it was not in good condition it sound's like someone there is a bit of a cowboy or the apprentice did it and said nothing if i were you i would not use them again Thumbs Up
Post #565088 Wed Sep 12 2018 6:13pm
Stevepd
Was it a LR indie? 2006 2.7 TDV6 HSE in Cairns Blue.
Post #565106 Thu Sep 13 2018 6:38am
Richythepom
Yeah - a LR specialist in Essex... 2008 RRS HSE Stornoway Grey
Post #565107 Thu Sep 13 2018 7:05am
