Home > In Car Electronics > Sat-nav, Bluetooth and Stereo has stopped working |
davecg69 Member Since: 04 Jan 2016 Location: Hampshire Posts: 8 |
This morning I took my RRS out and everything was working perfectly. Later, when I went out again, the Sat-nav just says “initialising”, the Bluetooth won’t find my phone (annoying as I get quite a few calls when driving) and the audio system is just greyed out and not working at all.
Tue Aug 07 2018 5:36pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
Have you turned it off and on again? Merc C220 estate Sport AMG
Tue Aug 07 2018 5:53pm |
Repeatedly .. |
Tue Aug 07 2018 5:55pm |
Hard reset ? Disconnect cables from battery and touch together ? Search the site for precise how to but may be worth a try ? |
Tue Aug 07 2018 8:27pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Any devices plugged in to USB ports? I had similar symptoms when a USB stick played up. The stick got very, very, hot. Removing the stick sorted it all out in a jiffy. 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 07 2018 10:23pm |
Thanks. I saw the earlier thread and tried taking the usb stick out, but no luck.
Tue Aug 07 2018 10:25pm |
Started her up this morning and all ok, with me doing absolutely nothing.
Wed Aug 08 2018 2:48pm |
the reason i asked if you'd turned it off and on again was that it happened to me once, a few months ago and all I had to do was stop, turn everything off and on again. I put it down to a glitch when booting up. It hasn't happened again.
Wed Aug 08 2018 2:56pm |
Thanks, Bill. Yes, I’m worried that it is! Might have to go down the dreaded “dealer route” |
Wed Aug 08 2018 4:33pm |
Could be a slightly loose earth somewhere. There are a few easy-to-reach ones in the engine bay that it would be worth checking at least. Others lurk behind trim and underneath. 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 08 2018 5:23pm |
