Home > In Car Electronics > Power for headrest Screen module under seats ? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
Certainly under the passenger seat on the early models, there is an ignition supply on the connector at the front of the seat.
Wed Jul 11 2018 12:06pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
Is the satnav unit under the drivers seat ? i did noticed a module with some Fiber leads going into it. |
Wed Jul 11 2018 12:19pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
No the Satnav unit is a integral part of the CD player in the center console, I think you will find the unit under the drivers seat is the TV tuner.
Wed Jul 11 2018 12:43pm |
yep you are correct just found one on ebay
Wed Jul 11 2018 12:46pm |
Should be a Grey 20pin connector on tv tuner, try pin No.1 red wire it is the power to tuner, controlled I think from fuse No.68 wouldn't know if it is ignition live or not though.
Wed Jul 11 2018 1:02pm |
Thanks for the help , Will try a multimeter on the pin if it is ignition live may have to up the fuse for the rosen screens . |
Wed Jul 11 2018 1:05pm |
In the end the better option was a fuse tap from passenger fuse box, pulled up sill trim and ran cable under , then a little bit under the carpet and then under the passenger seat .
Sun Jul 15 2018 7:19pm |
Can you post a photo? 2012 5.0 SC AB
Sun Jul 15 2018 9:24pm |
On mine it's where the surround camera control module is fitted, but assume other options can also be fitted to it as it's quite large with various mounting holes in it.
Sun Jul 15 2018 10:11pm |
Thanks Col ,
Tue Aug 14 2018 8:54am |
