Home > General > RR SPORT HSE TDV6 2.7 LOCKED UP SOLID |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
Is the belt tensionner missing in drivers side ? No
Wed Jul 11 2018 9:12pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
That's a snapped crank. Breaks between cylinders 2/3, pushed the front end of the crank forwards, and fractures the oil pump casing
Wed Jul 11 2018 9:23pm |
Markmarc Member Since: 09 Jul 2018 Location: Midlands Posts: 20 |
Hi .yes engine is painted black does that tell you its a recon or gen .pulleys were all there and intact ...i was thinking the crank has caused the crack being that low .time to looksee and find another block foing to pull the bottom tommorow and have a look at the destruction ..well i bought it on the understanding i was changing the engine but was hopeing for a crank.shell. change.and get away with a little work lol. |
Wed Jul 11 2018 9:46pm |
Yes with all that black paint it does point to a recon I would say. |
Thu Jul 12 2018 12:33am |
I would say going in for the third engine in a only a 100000 lifetime is not a good advert for these engines. |
Thu Jul 12 2018 10:25am |
Shame i cant find out whos fitted the engine and when was fitted it may be still under waranty that would have been a bonus lol .my heads ticking now im going off to do some research and check history on the documents ...ive found several cheap jags under 2k witb low miles and full service so will go looking and find the donor. |
Thu Jul 12 2018 10:40am |
check engine number v the logbook |
Thu Jul 12 2018 12:02pm |
Hi Disco mikey or Andy my question is how much hassle is it to change ftom manual back to auto box ive found a jag 2.7 but manual .is it just the torque flywheel and bell housing? Is the bell house a straight bolt iff bolt on change cheers m. |
Thu Jul 12 2018 4:03pm |
Hi Disco mikey ive picked up that 2.7 block sounds ok runs nice but what make shells would you recommend to replace existing ,Glyco.arp.king.etc i value your opinion cheers m. |
Fri Jul 13 2018 6:05pm |
I would be tempted to just leave it alone if it sounds fine.
Fri Jul 13 2018 7:13pm |
Hi Andy thanks for the info the jag is a 2005 110.000 mile good history to 80 ish and a 2 owner from new.shame to gas axe it up bit must needs .my mate said to leave the shells but i thought while its out to put some fresh in .going to flush engine and replace oil then drop again to give a clean it is well due a service.upgrade oilpump replace chocolate frame work cambelts etc..but glad you mentioned back belt forgot about that.has there been any call for the chains to be changed ? Anyyhing else im forgeting pls let me know cheers m. |
Fri Jul 13 2018 10:56pm |
You do hear the odd story of chain failure.
Sat Jul 14 2018 8:56am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Markmarc.. I think you may find it beneficial to join the sister Disco3/4 forum. Those guys are more into the DIY stuff. This forum is great, however more into enjoying the cars than repairing. Remember Disco is a Sport in working clothes. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Jul 14 2018 9:27am |
Just for starters
Sat Jul 14 2018 9:36am |
