Home > Technical > Rear spoiler |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
There is one large black torx bolt either side. (I think you just open the glass hatch to see them.
Thu Jun 21 2018 8:11pm |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 |
Thu Jun 21 2018 8:48pm |
Better take it off to find out why.
Thu Jun 21 2018 9:32pm |
Am I right in thinking if I needed to replace the camera or brake light you don’t separate the painted part from the black part
Thu Jun 21 2018 11:15pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
No you do not need to split the spoiler to change the camera or brake light, but obviously you do need to remove it from the vehicle to change either.
Thu Jun 21 2018 11:43pm |
do you still have a 2006 car ? |
Fri Jun 22 2018 9:43am |
No I now have 2010 but forgot to change in my profile |
Fri Jun 22 2018 10:28am |
Just removed the spoiler and found the adhesive that holds the black part to the painted parts had come loose so I have used a strong adhesive to bond them back together
Sat Jun 30 2018 5:28pm |
Seepee3o Member Since: 05 Dec 2020 Location: Hogsthorpe Posts: 12 |
Thanks Cosmo15555, my 2010 is the same with both half’s seeming to part - will apply the adhesive when it stops raining outside! |
Wed Mar 10 2021 12:07pm |
Well the adhesive I used was not strong enough! driving along at 50mph loud bang at the back as the spoiler detached and blew off leaving (thankfully) the camera dangling on the rear windscreen on its cable. Phoned Duckworth LR at Market Rasen who said pop down for a look. They inspected it, ordered a new spoiler under warranty (This is a 2010 RRS!) Spoiler currently being painted should get it fixed this week with new adhesive as per the recent recall - all FOC 2010 3.0 TDV6 HSE Luxury - Santorini Black - First RRS and lovin’ it |
Tue Mar 29 2022 2:30pm |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 78 |
As mentioned, this problem has been the subject of a recall for some time now.
Tue Mar 29 2022 3:19pm |
