Home > Maintenance & Modifications > gearbox oil level
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
gearbox oil level
I was checking the gearbox oil level the other day, I started to remove the drain plug, when oil started to come out, so I quickly refitted the drain plug. Should this happen, as I thought that with the car on the level, I should be able to unscrew the plug, and nothing come out.
(I've recently had a full oil flush/change done with the machine that changed the oil rather than just drain it.) Question
Post #559715 Sun Jun 24 2018 4:00pm
Disco_Mikey
Needs the engine running, and the gearbox oil at the correct temperature to check the oil level
Post #559720 Sun Jun 24 2018 4:24pm
CornishRob
OK, thanks Mikey.
So I should get it warm, leave it running then, unscrew the drain plug, and nothing should come out ? (just getting it straight Bow down Thumbs Up )
Post #559721 Sun Jun 24 2018 4:29pm
Tyrefitter
Don’t undo the drain plug or it will empty,,that’s why it’s the drain plug.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #559722 Sun Jun 24 2018 4:40pm
CornishRob
Ahem, yes I mean fill plug Embarassed Whistle
Post #559723 Sun Jun 24 2018 4:44pm
riverblanche
its not just "warm" but a Specific range of temp for the oil
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #559732 Sun Jun 24 2018 5:21pm
It doesn't need to be hot.
In this hot weather just run it for 5 mins.
Run it thru the gears and back to park and then check level with engine running
Post #559754 Sun Jun 24 2018 7:28pm
