Home > Technical > Squeaky suspension |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Rear hub bush makes a squeak when it's ready for replacement. That's the one that connects rear upright/hub to the suspension arms. Unlikely to be covered by LR warranty, sadly. Luckily, however, it's not an expensive job at a decent indy. 2012 SDV6 - it's missing a couple of cylinders
Fri Jun 22 2018 8:23pm |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
Just change the Bush? Would it be prudent to get both done? Obvs dependant on price. What are dealers usually like if they diagnose but you decide to go elsewhere would they charge? |
Fri Jun 22 2018 9:33pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
I have the same problem and it has been diagnosed by my Indy as the front ARB bushes. They squeak when surface rust gets caught in the bush. My bushes don’t need replacing but that is all that will get rid of the problem. The Indy lubricated them with a silicon lube and the noise disappeared for a couple of days. This hot weather doesn’t help either and if you drive through water it goes away.
Sat Jun 23 2018 2:46pm |
Not my front ARB bushes. All ARB bushes have been recently replaced |
Sat Jun 23 2018 3:45pm |
Easy way to check if it's a rear hub bush is to rock the car (reasonably vigorously) when it's sat on a level driveway. You'll hear the squeak and be able to pin point which side it is. 2012 SDV6 - it's missing a couple of cylinders
Sat Jun 23 2018 5:12pm |
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 |
£156.00 for them to have a look at the fault MY 13 3.0 SDV6 HSE Black Edition Santorini Black Ivory Premium Leather Side steps Disklok !!!!!!! Mud Flaps Spare wheel protector |
Sat Jun 23 2018 5:36pm |
Sun Jun 24 2018 7:32am |
require a 4 wheel alignment if replaced? |
Sun Jun 24 2018 7:42am |
says its the rear ARB bushes and as they are only just over a year old they will be replaced under warranty
Wed Jun 27 2018 6:55pm |
Hmmm. I bet it still squeaks shortly after they do the ARB bushes... 2012 SDV6 - it's missing a couple of cylinders
Wed Jun 27 2018 9:12pm |
