Home > Technical > rear timing belt |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8847 |
Do a search on here and Disco3.co.uk but from memory, yes the 3.0 does have to be timed. 2012 SDV6 - it's missing a couple of cylinders
Tue Jun 12 2018 4:08pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 386 |
Yes it is timed and a pain the arse as a vacuum pipe now further restricts access due to it being routed directly infront of the cover. |
Tue Jun 12 2018 5:33pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
It is timed, but no more difficult than a 2.7 belt
Tue Jun 12 2018 6:23pm |
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 |
Thanks, if I remove the old one and replace it with the now one with out turning the engine over, would that be ok, as that's what I did when I replace the one on my 2.7 engine and it was ok. |
Tue Jun 12 2018 7:42pm |
As long as the marks line up |
Tue Jun 12 2018 8:01pm |
Iggy Member Since: 31 May 2017 Location: Buckinghamshire Posts: 10 |
Sorry to tag on someone else's post not managed to start my own. Hi all a have a question I'm doing the rear belt on a rrs 3.0 having done the front. The crank/camshafts/fuel pump are all locked. Can I just fit the replacement belt ? Why would I need to line up the white lines on the belt with the line on the camshaft sprocket. I don't see any mark on the fuel pump drive. |
Thu Sep 20 2018 11:57pm |
what white lines are you talking about on the belt ? if its all locked in position just fit the new belt, if your useing the old belt it dosen't matter about any marks you put on it |
Fri Sep 21 2018 6:49am |
In theory, it will be fine as long as everything is timed up. The marks on the belt are there for correct alignment, to ensure the cam + pump are aligned In practice, it takes no extra effort to align the marks, so may as well |
Fri Sep 21 2018 7:22pm |
Hi all I have the rear belt on ignoring the white lines on it. I am struggling to get my arm down the back to fit the tensioner before l lock the fuel pump getting the pin in that will be a mission in itself. I have disconnected the vacuum pipe at both ends at the back to make more room. I think I'm afraid of dropping it an it getting lodged down the back. Any ideas would be greatly appreciated. I have checked the wife's arms an there bigger than mine which is worrying. |
Fri Sep 21 2018 7:32pm |
Regarding the timing belt white lines I could line up with the camshaft sprocket. However I cannot for the life of me see any line or indent on the fuel pump drive. Am I missing something? |
Fri Sep 21 2018 7:40pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
Have you removed the grill?
Fri Sep 21 2018 7:43pm |
The job goes on an on. The rear belt is on as is the tensioner before pulling the pin. I fitted the fuel pump locking tool to the drive sprocket which was easy. But the pin will not locate in the hole in the engine I can turn the sprocket maybe 5mm each way before the tool touches the casing and I have tapered the end of the pin and it fits fine without the tool attached.
Sun Sep 23 2018 8:41pm |
