Home > General > Turbo replacement - cost |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
Expensive.
Sat Jun 02 2018 7:02pm |
nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113 |
I have never done it, but I have read that it can be done through the wheel arch, but not easy. |
Sat Jun 02 2018 9:00pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 747 |
Is it actually the turbo that has failed? The reason I ask is that a sticking variable vane actuator is a common problem resulting in reduced performance. There is an updated part to rectify this and i understand it can be done with the body on. A lot of owners have managed to free it off using a bit of wire and grease. Worth looking into initially. |
Sat Jun 02 2018 9:56pm |
The experts say it can be done easily in 10 hours lifting body.
Sat Jun 02 2018 11:02pm |
£3.7k for an sdv6 though that is both turbos and a body off job. Indy price. Should be less for 1 turbo even at main dealer prices as the turbos alone are around £1200 each for Garrats. |
Sun Jun 03 2018 12:17am |
Have a look at this
Sun Jun 03 2018 8:18am |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 310 |
Unfortunately I can't give the codes as the garage hasn't given them to me. After they carried out the diagnostic (for which they didn't give me a bill - which leads me to feel they didn't find a problem and they don't want to take any responsibility). All they did say was they thought it was the turbo causing the problem of the ENGINE SYSTEM FAULT message showing on the dash - they sent me on my way saying come back if the warning comes up again. It's a 2006 Sport and hasn't done 100,000 miles. The guy who usually looks after servicing for me gave me a and told me to PUT YOUR FOOD DOWN MORE OFTEN which I do now and use a better grade of diesel.....any other thoughts as to how I can try to fee up the turbo gratefully received!!! Andrew Kennedy |
Sun Jun 03 2018 3:29pm |
PDC Member Since: 13 Dec 2015 Location: Warwickshire Posts: 163 |
My turbo failed last year with only 15k on my Disco, which is the same vehicle as the Sport. Luckily it's still under warranty otherwise it would have cost me 6k and they did lift the body the change the turbo.... 2010 RR 5.0 Autobiography
Sun Jun 03 2018 9:12pm |
you don't want to be changing the turbo, if it "might be the turbo".
Sun Jun 03 2018 9:34pm |
Thanks for yours!! I've had a look at the video - it's something I would certainly like to have-a-go-at. Would you say the car needs to be up on a lift, or possibly could be done by crawling under the car?!? Andrew Kennedy |
Mon Jun 04 2018 4:48pm |
Iv'e never had the need to do it myself, thankfully. If access is via the wheel arch, I imagine jack that corner up, axle stand under the chassis rail, wheel off and get stuck in. I would think that it would be a lot easier if you have access to a lift though. |
Mon Jun 04 2018 11:11pm |
Yes exactly as above.
Tue Jun 05 2018 12:03pm |
faby2020 Member Since: 06 Nov 2020 Location: beausoleil Posts: 1 |
Good morning,
Fri Nov 06 2020 4:22pm |
