Home > Technical > 2010 Dashboard Airbag & ECU Replacement Advice |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
I think you will find the Restraint Control Module is under the center floor console, not sure how much you have to remove to get to it though. Quite a bit of stuff has to be removed to replace top dash and passengers air bag, but not to difficult though, just a lot of screws and clips and a few electrical multi-plugs. Need to remove some of center console as well so halfway to restraint module access.
Sun May 27 2018 6:50am |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 |
Cheers Col
Sun May 27 2018 4:06pm |
Not to sure about the warning lights, but did find this in the w/shop manual.
Mon May 28 2018 8:53am |
I had a ding in mine not too long ago, curtain airbags, seats and seat belt tensioners all fired. I sourced all parts second hand and had no problems. Like yourself after looking around I was worried about the ECU and the wiring loom due to all the other misguided 'advice' that's doing the rounds. So to lay it out straight:
Tue May 29 2018 10:40am |
