Home > Technical > RRS 2008 strange behaviour with air suspension
sestorious
England 2008 Range Rover Sport Supercharged HST Santorini Black
Hi all, have a bit of a problem an i know you guys can help.
So, i went to skegvegas on friday, en route the orange suspension light came on. After a while it went off then on off and so on. Then the front end only dropped unti i sent suspension to off road and back to normal.
The same thimg happened saturday BUT sunday it went red and dropped to the bumps. Turned car off had a fag, and when i started car, no issues.
Then the orange light escapade started again.
Today ive plugged her in at mymates garage and we got the following:
C1A72 front left height sensor mechanism
C1A03 front left height sensor
U0421 invalid data received from ride level control module
U0132 lost comms with ride level control module
I must say this is intermittant as ive just been out in it and no issues.
We watched the height sensor mechanism whilst sending her up and down and both “seemed to work ok”
Is this simply, a new height sensor or am i looking at something more serious ?
Thanks all in advance !
Post #556010 Tue May 08 2018 5:47pm
sestorious
Hi sorry to bump, but can anyone advise ?
Thanks
Post #556074 Wed May 09 2018 2:53pm
give the wiring to that sensor a good inspection then replace sensor
Post #556090 Wed May 09 2018 7:25pm
sestorious
Thanks for that !
I’ll have a look an replace the sensor.
Can they intermittently fail as in my description?
Post #556141 Thu May 10 2018 3:47pm
don't know
wiring probs are more common
Post #556152 Thu May 10 2018 5:42pm
sestorious
So aside from a visual, can I do any electrical testing on the wiring ?
Post #556155 Thu May 10 2018 6:20pm
With it so intermittent it's not easy.
Post #556171 Thu May 10 2018 8:20pm
sestorious
So it’s just failed with yellow light again.
Checked the 4x4 on the display and shows left front low although suspension is sat level.
If it’s hard to check wiring I’ll just change height sensor and see how that goes.
Post #556223 Fri May 11 2018 8:15pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
I'm having similar problems. 4x4 info showed o/s/f sensor at lowest point. changed sensor and while I was in there I changed the wiring as at some point somebody has snapped the locking lugs off the plug. Still getting amber suspension light and 4x4 info showing that wheel low. Live data on the diagnostics shows voltage going to the sensor but nothing coming back. I got another sensor from my independent as thought it was a faulty one they had given me; NOPE, fault still there. Therefore I suspect a wiring fault between where I soldered in the new wiring and the ride height control module. I am stuck offshore so can't sort it, but not looking forward to trying to trace it Rolling Eyes
Post #556232 Sat May 12 2018 2:19am
Brit Plumber
I wonder if earthing that wire at that point you soldered it would help diagnose the issue? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #556266 Sat May 12 2018 1:19pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Hi, I know this is an old thread but I have exactly the same fault codes, did you get a fix in the end? Replaced sensor?
Post #601381 Mon Jul 06 2020 11:26pm
