Home > Maintenance & Modifications > Automatic Transmission Fluid - Flush and Change
gogsy1956
Flushing the Gearbox is done using a specialised machine,,, it's similar to a dialysis machine,,, it removes 100% of the old fluid and replaces it with new, without mixing the two. Just draining and refilling the Gearbox would only change half of the oil. A lot of people also add Dr tranny, which is an additive of sorts that also aids lubrication of older units. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #555962 Mon May 07 2018 8:04pm
Eaters
Danny1 wrote:
Hi Cupra,
I see you are in Kent, can I ask who you used and what sort of cost?
I have been told of a mobile chap in your neck of the woods?
This may help. There's a chap (geoff.) on here who is mobile but based in Edenbridge. I think he's more active on the Disco 3 site but if you search for "geoff." (the full stop is important) you should find more about him.
For example: http://www.rrsport.co.uk/forum/topic44001.html Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #555981 Tue May 08 2018 7:11am
mf175
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Isn't the transmission fluid filter built into the sump pan therefore the whole sump pan has to be replaced???
Post #556084 Wed May 09 2018 5:09pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
In Australia many independents recommend you change the Transmission fluid before or around 100K KM's
(60K Miles), no later, as well as change the pan, not a crappy LR plastic one, but a steel pan.. Overall
charges typically vary from between 600 to 1000 pounds for a dual flush and new pan.
Love to know how it can be done so much cheaper in the UK Laughing the transmission fluid is very
expensive here Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #556946 Sun May 20 2018 12:29pm
well they don't change the filter. (which I can understand)
and they probably use red fluid
Post #556959 Sun May 20 2018 2:36pm
