Home > Technical > Cam belts. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
Yes the front belt will cause the clash.
Fri Apr 20 2018 11:28am |
harrij Member Since: 30 Jan 2018 Location: Nantwich Posts: 12 |
Cheers Andy, what think you of 130K on same belt, don't think I would chance it? Regs JH. |
Fri Apr 20 2018 11:56am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
I'd be more concerned about the oil pump... |
Fri Apr 20 2018 12:56pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 576 |
Metal ware like Mike has said will be the first to fail before a belt does |
Fri Apr 20 2018 2:09pm |
I have my belts change coming up on my 2012 3.0 sdv6. Is the oil pump an issue there ? What else is worth changing out and replacing at the same time ? |
Mon Apr 23 2018 11:46am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
The oil pump issue was on the 2.7TDV6 from around 2006-2007 (not sure of the exact time period). The problem with the SDV6 appears to be access to do the job - see https://www.disco3.co.uk/forum/sdv6-timing...54-15.html 2012 SDV6 - it's missing a couple of cylinders
Mon Apr 23 2018 12:25pm |
No, just belts And its not a body off job either |
Mon Apr 23 2018 12:45pm |
Cheers Mikey. That's a relief. |
Mon Apr 23 2018 1:36pm |
That's good news! 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Apr 23 2018 1:49pm |
My previous employers still lift the body to replace the belts, and are more expensive than the main dealer |
Mon Apr 23 2018 2:18pm |
Theiving etceteras Mikey.
Mon Apr 23 2018 4:37pm |
