Home > Faults & Fixes > RRS 2010 5.0 Supercharged strange coolant leak |
davidfo Member Since: 12 Apr 2018 Location: Berkshire Posts: 9 |
My RRS has a strange coolant leak, that only occurs around the Coolant Expansion tank, and only when I put my foot down.
Thu Apr 12 2018 8:38pm |
Thanks, it's only under load when I put my foot down, steam out of the uk nearside front bonnet. Open the bonnet and there's coolant spray around the expansion tank area.
Fri Apr 13 2018 8:26am |
Was it bled properly as these are bad for getting air locks |
Fri Apr 13 2018 6:21pm |
That's a good question, I am hoping it is this and the Undue mentioned it did have an airlock. What's the best way to bleed these beasts?. |
Fri Apr 13 2018 8:25pm |
Have a quick search on here it should be explained |
Fri Apr 13 2018 8:32pm |
So after bleeding the system I still have a leak. It only happens when warm and when putting my foot down and seems to come out of the coolant return pipe or connector?, on top of the nearside of the engine. I replaced the original clip with a jubilee this morning thinking it was the clip, but maybe there is a rubber seal in the plastic connector, or it is leaking from the plastic connector going into the supercharger? - see pic...thanks. |
Wed Apr 18 2018 10:03pm |
Wed Apr 18 2018 10:04pm |
Just to respond to my own message, I still have a coolant leak to my dismay, however, thought I would post back to advise I was sorely mistaken thinking the pipe clip I replaced was a coolant pipe. After tracing the pipe further, it was a pipe that went into the intake in the front of the engine.
Tue May 01 2018 9:17pm |
