Home > Technical > air bag light on |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
Not sure if this is of any use, taken from Workshop Manual,
Wed Apr 11 2018 4:05am |
Alfa Rover Member Since: 15 Dec 2016 Location: Vancouver Posts: 19 |
Hello Col, thanks for the quick reply. i don't have a workshop manual, next on the wish list. ok , by the sounds of that i guess i am looking for an impact sensor. location left hand side front door? i will google the location to see if i am correct. thanks for pointing me in the right direction. if you uncover any more information please post as this air bag light seems to be quite a common problem. of course the air bag light can be triggered by many other sensors and pin pointing the exact cause can be frustrating. Col thanks again for your help, i will post my progress. Cheers Neil. |
Wed Apr 11 2018 7:04am |
Neil,
Wed Apr 11 2018 7:34am |
Hello Gents, first off thanks again to Col, just a update to the air bag light. after looking around for some time checking connector plugs ect. i have traced the fault to the drivers door harness. whilst opening the door with the engine running, the air bag light came on and the chime also was on as well.
Tue May 08 2018 4:15am |
Marcin2112 Member Since: 20 Aug 2021 Location: Warszawa Posts: 2 |
Please send me front airbag sensor harness wiring diagram for rrs sport 2014, my email: marcinciesielski.jw@gmail.com I have a broken beam from the right sensor and I do not know how to connect it. Thank you very much and regards Marcin |
Fri Aug 20 2021 7:58pm |
