Home > General > Oil pump question
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
Oil pump question
I read on a thread somewhere that if changing the 2 belts at the front (auxiliary) that shortly after there is a chance of the oil pump failing?? How big a job is this on a tdv8 and should I be concerned as my car has just done 102.000 and I am having the two belts changed .......is it just bad luck if oil pump goes or is it a common fault to be aware of 😩
Post #551373 Wed Mar 14 2018 6:39pm
Disco_Mikey
TDV8 does not suffer from oil pump failure in the same way the TDV6 does Thumbs Up
The 2 belts you will have replaced are the aux drive belts Thumbs Up
Post #551397 Wed Mar 14 2018 9:42pm
Alfie
That’s a relief 😁 thanks for putting my mind at rest πŸ‘πŸ‘
Post #551452 Thu Mar 15 2018 2:04pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Would you recommend oil pump changevwhen doing the belts on a 2012 my sdv6 ?
Post #551556 Fri Mar 16 2018 8:57am
