Home > Maintenance & Modifications > automatic activation of front & rear demisters ?
No nickname
Denmark
Just noticed that the front screen & rear window electric demisters / heater elements are automatically switched on when I start the engine.
Is this a software fault, a menu option, or is the switching on triggered by sub-zero temperatures ? Thanks Nick
Post #547524 Sat Feb 03 2018 4:47pm
Mine does it too. It only happens in low temperatures and appears to be a function added by LR during the facelift. Earlier RRS didn't do it. 2012 SDV6 - it's missing a couple of cylinders
Post #547537 Sat Feb 03 2018 5:21pm
No nickname
Denmark
This explains why the battery is nearly flat all winter time Mad
Post #547544 Sat Feb 03 2018 5:53pm
Only if you do short journeys, I would suggest. 2012 SDV6 - it's missing a couple of cylinders
Post #547546 Sat Feb 03 2018 5:59pm
Smarttech
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Mine does this every time you start the car if the temp is low and the snow flake is displayed. 4 degrees or below I think.
No snow flake, No heated screens coming on. 2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior.
Post #547556 Sat Feb 03 2018 7:44pm
Indeed so. They can be turned off by pressing the buttons so it's not a real issue. 2012 SDV6 - it's missing a couple of cylinders
Post #547569 Sat Feb 03 2018 9:22pm
Smarttech
That's exactly what I do if they don't need to be on. 2 button presses problem solved 2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior.
Post #547572 Sat Feb 03 2018 10:19pm
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
My heated rear screen is on even when the buttons aren’t turned on,,must be a fault on it so I’ll mention it to LR when it goes in for next service
Andy Andy.
2014 RRS SC santorino,coris roof.
2014 Evoque D-Lux Fuji
Previous motor.
2016 VW Amarok Highline,candy white
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
Subaru wrx sti widetrack
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #547586 Sun Feb 04 2018 9:15am
