Home > Wheels & Tyres > Tyre tread pattern explanation please |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Have the tyres been fitted the correct way round as I think the latitude sport is a Asymmetric tyre and there should be a marking on the tyre saying "Outside" which obviously goes to the outer face of the wheel rim although the rim can be fitted either on the O/S or N/S of the vehicle as long as "outside" is to the outside it is fine.
Wed Jan 24 2018 10:31am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Yep all 4 tyres have OUTSIDE on the outside. I'll try and post a photo for a better explanation.
Wed Jan 24 2018 11:08am |
Here we go. So if you look at the groove and its orientation by the word outside. Now imagine that's fitted on the LHS of the car going forward. If you fit the same wheel/tyres on the RHS (or vis versa) the grooves go the otherway?
Wed Jan 24 2018 11:12am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
I have just had a look at the 20" P Zero's on my F type Jag which is hibernating. All tyres have "Outside" & as you say the grooves face forward on the offside & rearwards on the nearside another marketing gimmick perhaps |
Wed Jan 24 2018 3:48pm |
Wed Jan 24 2018 9:25pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
The inside shoulder is designed with different block and groove densities to those on the outer shoulder. This is because the shoulders do different jobs, or rather are designed to deal with different conditions. Hence the different look across the tread and hence the "outside" marker. The direction of the grooves is less important here than might be expected.
Wed Jan 24 2018 10:22pm |
