Home > General > Advice on Diesel
Stevepd
Advice on Diesel
So I do 64 miles a day commute and currently use Morrisons diesel with no problems in running and getting roughly 29/30 mpg. Now I've got the idea of occasionally putting in the premium Diesel. Locally to me is Esso and BP with the nearest Shell being 18 miles away which is still possible but just means I drive to work a different way. Which brand would you recommend?
Steve 2006 2.7 TDV6 HSE in Cairns Blue.
Post #545671 Fri Jan 12 2018 6:21pm
Tim in Scotland
I would just stick with your supermarket stuff, i’ve Run my SDv6 for nearly 3 years on mostly Sainsbury’s ULS Diesel with no apparrant problems but a big saving to my bank account! Where I live we have a difference of 5p a litre ( even more if you use the alleged better “super” diesel) between supermarket diesel and the same branded stuff from the majors forecourts. Often the fuel on the branded forecourts comes from the same refinery as the supermarket stuff, remember, supermarket fuel is often a loss leader just to get you into their shops. 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #545674 Fri Jan 12 2018 6:32pm
Stevepd
Thanks Tim, I'll stick with routine then. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #545712 Sat Jan 13 2018 6:38am
Eaters
I decided recently that it would do no harm to occasionally add a fuel additive (I chose Wynns) to help keep everything a bit cleaner. I have some concerns about the turbos (and injectors??) and anything I can do to delay the need to replace them (I am on 72,000 miles) I thought worthwhile. But at £10 - £16 per pot these additives aren't cheap. And a quick calculation tells you that, even at 10 per litre more expensive, buying a tankful of super diesel (say 70 litres) is £7 a time extra. That's about half the price of the additive. So I now occasionally fill up with the special fuel Esso or BP normally, rather than use the Wynns. Robin
Awaiting rebuild: NGTF
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #545716 Sat Jan 13 2018 7:53am
Tim in Scotland
The only non supermarket fuel that has gone into my car is Shell standard diesel from their Lancaster north filling station which is 5 minutes drive off the M6 junction 34 or the Esso station at Gaydon Village just off the M40 which is also just off the motorway and both are 20-25p cheaper than fueling up on the nearby motorway service area. I have used Wynns diesel additive in my Defender but haven’t seen much benefit from it as I don’t do more than 1000 miles a YEAR in it so running 4-5mtankfuls with additive through the system takes for ever. 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #545732 Sat Jan 13 2018 9:57am
riverblanche
Hi Steve,
I use asda std stuff and no additives
in the previous, 3.0tdv6, two 2.7tdv6, a 2.5td5 and our merc 320 I used supermarket diesel and 2sO Shocked
when you have a spare Day to read threads, some on here and lots on D3
Thumbs Up Corris HSE Dynamic 2016
Always pick up stick in the middle !!
Post #545772 Sat Jan 13 2018 8:07pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Sainsburys or BP standard for me, but only as they are convenient. I don't care really. I have never, ever, in 30 years driving, had any fuel related issue over cars or vans of all shapes and size. This includes 3 years nearly in the RRS. I do between 12 and 15k miles a year. Once every three months a shot of Wynns xtreme (7 quid a bottle) and 100ml a full tank of Millers. Drives as smooth as you like and with a 300bhp Alive remap it is a quick car when needs be. No DPF lights, performance issues, anything.
I would imagine the cost would be similar to BP ultra all the time. Who knows. Not much in it. You pays your money and takes your choice but bog standard supermarket fuel is perfectly fine.
Post #545817 Sun Jan 14 2018 12:13pm
