Home > General > suspension fault
stebenny
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
suspension fault
I am sure this will be covered somewhere But i have started getting the "normal ride height only" warning for the suspension
if a start the car the suspension raises and lowers fine with no problems the message only comes on after i have been driving for a few minuets Any ideas Thanks Steve
Post #545692 Fri Jan 12 2018 9:57pm
Disco_Mikey
Worn compressor or air leak Thumbs Up
Post #545720 Sat Jan 13 2018 7:59am
stebenny
Thank you for the reply Would i be able to tell if there was a leak has in i would be able to here the air leaking and if its the compressor could i replace the seals our should i just buy a new compressor Thanks for your help
Post #545764 Sat Jan 13 2018 5:01pm
