Home > Maintenance & Modifications > 2009 RRS transfer case oil |
dalmat Member Since: 09 Sep 2015 Location: Split Posts: 36 |
I had the same problem and while searching I ran onto info about this product
Mon Dec 18 2017 10:34am |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
As far as I am aware, there are a few alternatives but they do not have the long life additives of the genuine stuff. It is fine to use the alternatives just need to change the oil more often. MY12 RRS HSE
Mon Dec 18 2017 3:19pm |
I agree with shepp. This is good alternative when original oil is hard to find or not available, but more frequent change is advisable. |
Mon Dec 18 2017 3:28pm |
exopar Member Since: 23 Aug 2017 Location: Veracruz Posts: 15 |
Ravenol products can not be found in Mexico.
Mon Dec 18 2017 7:16pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
do you not have any LandRover dealers ?
Mon Dec 18 2017 7:23pm |
The only Land Rover dealer available does not supply that fluid neither can order it for me hence need to get any alternative that can be purchased localli. |
Mon Dec 18 2017 7:27pm |
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 |
Dalmat, have You used Ravenol and if you have how often did you change fluid? Tks. |
Fri Dec 29 2017 3:56pm |
Just to let you know guys, Motul has a Gear 300 LS fluid that is Land Rover aporved for transfer case.
Fri Dec 29 2017 5:16pm |
I just use it after changing bearings and my intention is to replace it after short time to see condition. Anyway, my guess would be to check the fluid regularly and change it a little bit sooner than user manual suggest. |
Fri Dec 29 2017 6:12pm |
Motul do some excellent oils, usually far better than the original, just one thing to check is if it has the long life additives. The transfer box can
Fri Dec 29 2017 8:08pm |
