Home > General > Water on passenger side
I pulled up the trim along the door shuts and found quite a bit of water down there.
As I don't have a sunroof, anyone know where it commonly comes in ?
Thank you
Post #543604 Sun Dec 17 2017 6:05pm
Eaters
Is this any help?
http://www.rrsport.co.uk/forum/topic48466....creen+leak Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #543610 Sun Dec 17 2017 7:02pm
Thanks you.
Pollen filter was dry last time I looked but will recheck.
AC Drains do work, well on one side at least
Post #543612 Sun Dec 17 2017 7:25pm
Stevepd
Just had the same thing with mine and it was the windscreen trim proud of the screen by a couple of mm and let water in via the filter. Easy fix though.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #543614 Sun Dec 17 2017 8:05pm
Paddi
Andy,
Sorry to hear that - water ingress to the cabin is bad news especially when the weather is cold like right now.
I wonder if it's the windscreen pillar leak problem? Pull off the external trim and check the hole is taped over and the securing clips have correct gaskets in good condition. There's a TSB about it and a repair kit part number DHB500430 . 2008 MY Java Black TDV8 HSE
Post #543615 Sun Dec 17 2017 8:11pm
Thank you.
Will check
Post #543618 Sun Dec 17 2017 8:40pm
filter dry.
appears to be the front door seal.
at the front, is wet.
Post #544393 Sat Dec 30 2017 5:46pm
Just found my mat wet after it being ok for months well years lookin at this thread
Water coming out of pollen filter door and filter wet so at least I see a source this time
Post #594178 Sun Feb 02 2020 12:44pm
knwatkins
This is down to a poor design of the intake under the scuttle panel.
When I took my scuttle off to spray it last summer, I made a little water deflector in case the seal around the scuttle was to ever fail. After fixing the root cause, it could be worth you doing some thing like this Andy.
It's simply the side of a plastic milk bottle, stuck in place with a decent amount of silicone sealant. Simple but it does the job...
 Kev
Post #594186 Sun Feb 02 2020 1:43pm
Thank you. Thumbs Up
Will do that.
22/2/20 - Added milk bottle plastic, above metal with 2 holes, that align with the trim clip holes
Post #594193 Sun Feb 02 2020 3:52pm
Stevepd
Same, I did mine as above 2.5 years ago and it’s been dry ever since Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #594195 Sun Feb 02 2020 4:12pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Watch that grommet in the photo, mine was dislodged when I got mine and it’s directly above the main engine ECU and allowed water to get into it, was a bit of a nightmare getting it fixed. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #622960 Sun Mar 20 2022 1:43pm
As the vast majority of owners don't have an issue, I think this "reason" is a bit spurious.
I've driven mine through some fairly horrible conditions with not a drop in the footwell. I haven't however, jet washed it to within an inch of its life. I have jet washed it, I should note, but never had a problem. What is it that people are doing that is causing water ingress through the cabin air intake? 2012 SDV6 - it's missing a couple of cylinders
Post #622968 Sun Mar 20 2022 8:16pm
You don't have to mod yours if you don't want to !
It's a combination of poor design. and the seal on the scuttle getting old.
Simply with the car parked up water can get in, as the air in take sits further out than the bottom of the windscreen
Post #622969 Sun Mar 20 2022 8:35pm
knwatkins
It is poor design, whichever way you look at it. This is not a spurious statement. The design should be suitably robust to not let water into the cabin if it should pass between the bottom of the screen and scuttle. This is clearly not the case and something that could have been easily avoided if the intake design was a slightly different shape as to not protrude the bottom of the screen.
Prevention is better than cure, especially if you're already working in that area. As I was removing to paint mine, it was a no brainer for the sake of 5 mins of my time and no downside. Kev
Post #622970 Sun Mar 20 2022 9:15pm
