Home > General > Crankshaft pulley
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Crankshaft pulley
Morning all
I have just started to bolt on all the ancillaries
On to my engine 2.7 sport in my garage
After haveing it back from engine specialist
Had oil pump tensioner sheer off
Which caused quite a lot of damage
New valves rockers rings line bored so on
Also crank under X-ray revealed crack
So have sourced another crank
My question is which I'm unsure about is this
Can the pulley bolt on to crank anyway with 6 bolts or does it go
On in a certain way
Is it balanced basically
Thanks in advance for any help
Post #543411 Fri Dec 15 2017 6:21am
Bullnogger
Forgot to say engine is built up complete
Timing belt on just need to no if crank pulley
Is balanced and can only be fitted to crank or
Can be fitted anyway thankyou
Post #543421 Fri Dec 15 2017 11:46am
I am not aware that it is balanced.
Obviously you need to put the locking pin in by the starter when aligning the cambelt
Post #543428 Fri Dec 15 2017 12:45pm
Bullnogger
Thank you for reply much appreciated
Yeah cam belt on engine already also flywheel done
By engine specialist all timed up
all I need to do is bolt pulley on crank
Useing the 6 bolts
Post #543455 Fri Dec 15 2017 6:03pm
