Home > Maintenance & Modifications > EML light |
90000 miles for the plugs make sure the oil filler is secure and also the fuel tank cap as this can effect the system as i was getting them a lot whilst running on gas in mine so made sure they were tight and no more codes since may not be your issue but its a cheap starter to be getting on with |
Wed Nov 29 2017 7:45pm |
Tome Member Since: 20 Mar 2016 Location: West midlands Posts: 21 |
Ahh intresting. I have no oil leak on it but will check the filter any way. Was the seal split on the cap then?
Wed Nov 29 2017 9:28pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
90,000 miles, not 9,000 |
Wed Nov 29 2017 9:35pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
Well if you get desperate.
Thu Nov 30 2017 12:35am |
Was there not an issue with high miles S/Cs of the MAF getting dirty/ an oil film on the sensor and cleaning it solved this problem? I am probably wrong on this but i’m Sure that there was a post either here or on FullFatRR about these codes and the cause was as above 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Nov 30 2017 10:44am |
I would suggest you don't clean the MAF sensor until you are sure / do research.
Thu Nov 30 2017 1:11pm |
