Home > General > Detachable towbar won't fit
Ollyhall
Well I'm really chuffed I signed up on here so far it's been a massive help! Thanks everyone!!
Post #471893 Thu Sep 03 2015 7:57pm
Brutus
England 2006 Range Rover Sport TDV6 Autobiography Java Black
Towbar
Hi All,
When the tow bar is attached, does the green knob go in to the fully vertical position? I can only get it to the horizontal position.
Post #479645 Thu Nov 12 2015 10:00pm
DrRob
http://media.disco3.co.uk/ownerinfo/KNB500...ndbook.pdf Visitor from fullfatrr.com
2011 Vogue SE 4.4 TDV8 Full Fat
GONE - SDV6 HSE MY2012 in Orkney Grey.
1993 200Tdi Tdi Range Rover - a proper Rangie!
1949 Series One 80" in family since 1975! Where it all began.....
Post #479650 Thu Nov 12 2015 10:26pm
Brutus
Many thanks Dr Rob, that makes sense.
When I tested the tow bar outside of the housing the knob goes fully vertical. That's why I thought it may not be fitted properly as it only goes to horizontal (must be an age thing).
Post #479709 Fri Nov 13 2015 2:07pm
MMP
lamb190 wrote:
MAKE SURE YOU "PULL" the green lever as well as twist it! (you need key in and turned)
THANKS Lamb190 THE HAMMER DIDN'T WORK BUT PULLING THE GREEN LEVER AS WELL AS TURNING DID!
Post #541937 Mon Nov 27 2017 12:42pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
