Home > Technical > SPRINGS AND SHOCKS |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
In theory, you could do it. The early Disco3 was available with coils but not sure the RRS ever was.
Thu Nov 23 2017 10:34pm |
Nige Member Since: 29 Oct 2017 Location: lancashire Posts: 82 |
did the p38 a while back , its got a kit to retro fit, worked a treat BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Thu Nov 23 2017 10:37pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4339 |
D3 on coils drive like a pile of
Thu Nov 23 2017 10:38pm |
can't be any worse than the air bags ? I've run my sport now for a while and comparing it to our other l322 the sport really is harsh ,,even putting the 19 inchs back on,,i will get the body off this new one and have a measure up,for a kit I've found with EAS software, to cope with the conversion BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Thu Nov 23 2017 10:42pm |
The L320 will be different to the L322. It's supposed to be. The L322 is considered "floaty" by some, after all.
Thu Nov 23 2017 10:53pm |
being honest,,we have 2 discos and the older l322, the sport just does not feell strong enough,feels a lot more delicate,maybe its just the way it is,,will take the body off the latest addition and will post the results, BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Thu Nov 23 2017 10:59pm |
A grand to make it a worse vehicle?
Thu Nov 23 2017 11:00pm |
What do you mean by "delicate" and "strong enough"? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Nov 23 2017 11:01pm |
when your off road and you hit the mother of all ruts, feels like its going to break, we have these vehicles off road every day in our work,don't know maybe just used to the discos BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Thu Nov 23 2017 11:06pm |
You are aware that the RRS and Disco3 are the same under the skin, right? The wishbones are interchangeable, for example. If the RRS is showing an issue where the disco isn't, there's a problem to be fixed. Sounds like bushes need changing, to be honest. I've used my RRS off road and when the lower arm bushes are dying it feels like the wheels will fall off!
Thu Nov 23 2017 11:20pm |
new tank cover every month then BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Thu Nov 23 2017 11:21pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
If you dont like air suspension why did you buy a RRS (exactly the same as a D3 under the skin) - maybe you should have bought a Crapota.
Fri Nov 24 2017 2:20am |
got 2 sports now , body off the second one will post some pics when i start the conversion BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Fri Nov 24 2017 8:25am |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
Nige, have you seen this, might be of some help. https://www.disco3.co.uk/forum/air-coil-conversion-166104.html |
Fri Nov 24 2017 6:25pm |
