Home > Technical > Oil leak! |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 |
Hi everybody!
Sat Nov 11 2017 8:00pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4798 |
Gasket but they aren't cheap!!
Sat Nov 11 2017 8:02pm |
Ok, thanks Andy! |
Sat Nov 11 2017 8:21pm |
Whilst I am on with my maintenance, can I also ask for advice on the following:
Sat Nov 11 2017 9:05pm |
Sorry. Don't know about amk compressors |
Sat Nov 11 2017 9:17pm |
Compressor is quite the normal thing, but it can be a very small hole in the pipework and which can be very difficult to find.
Sat Nov 11 2017 10:46pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
C1A20-64 Pressure Increase Too Slow When Filling Reservoir - Signal plausibility failure Signal plausibility failure Gallery pipe air leak Air supply unit fault Reservoir pipe air leak Reservoir air leak Intake filter blocked/restricted Intake pipe blocked/restricted Air suspension intake silencer blocked/restricted Corner valve stuck open Where available, refer to the guided diagnostic routine for this DTC on the approved diagnostic system. Check the Air suspension intake pipe and silencer for blockage/restriction. Cheers Col |
Sat Nov 11 2017 10:57pm |
