Home > General > Buying a 2008 TDV8 - what should I look for? |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
If it's been sat around then the Electric Park Brake could become an issue. Others on here have found this, and mine failed within weeks of buying it having sat on the forecourt for a few months and only covering 500 miles the previous year. 13MY Range Rover Sport Autobiography SDV6 - mine
Fri Sep 22 2017 10:07am |
pablo Member Since: 21 Sep 2017 Location: Watford Posts: 4 |
Good to know, I heard the electronic parking break is about a 2K repair, is that even remotely accurate? Sounds extortionate! |
Fri Sep 22 2017 10:29am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
£2k is rather exaggerated. even at main dealer rates...
Fri Sep 22 2017 12:36pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
The EPB issues are usually at the wheel hub end, not the module itself. The brake shoes do need to be maintained and adjusted. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Sep 22 2017 2:10pm |
Turbo's can be a problem too |
Fri Sep 22 2017 4:20pm |
So can fuel consumption. John
Fri Sep 22 2017 4:26pm |
Thanks for the tips guys. I'll be extra vigilant tomorrow, thankfully the owner is going to get it MOtd too so i shouldn't have anything to worry about! |
Fri Sep 22 2017 4:39pm |
Not to sure about that one theirs loads of other parts to worry about that are not under the mot like air-con,electrics etc |
Fri Sep 22 2017 7:27pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
There is a buyers guide around somewhere. Worth a read.
Fri Sep 22 2017 10:59pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I bought a 2008 TDV8 20 months ago. Without a reasonable warranty I would be seriously out of pocket. You would not expect the items I've had repaired to go at just 60 thousand miles but, from memory, (as I'm on hols at the moment) front diff, 2 wheel bearings, both front lower wishbones, EPB seized. So far I've had some £1600 paid for by my warranty company at a cost of £925 and I still have 20 months of warranty to run.
Sat Sep 23 2017 1:37am |
Who did you opt for with the warranty, Eaters? |
Sat Sep 23 2017 1:53am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
You wouldn`t like mine then Steve. |
Sat Sep 23 2017 3:31am |
When I bought the car I was given the "Ultimate" option from The Autogroup (www.theautogroup.co.uk). I'd never heard of them before but they seem to have looked me quite well. Probably put the kiss of death on it now! One thing they don't cover, and you may not even think to check it on when you buy, is the headlamps. If its fitted with the AFS (all singing all dancing) headlights, and they are not working properly, then a brand new replacement headlight is just short of £1000 (second hand about a third of that). Yes, that's EACH! There are plenty of threads on here (including mine) about the issues with them. Seems its an intermittent fault, so be careful to check as much as possible. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Sun Sep 24 2017 11:09pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4798 |
Why don't they cover AFS lights ? cus its an option ? |
Mon Sep 25 2017 12:27pm |
