Home > Technical > 2010 RRS TDV8 - Massivee Brake Vibration & Steering Shim |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 192 |
Certainly sounds like a warped disk, I had mine skimmed while still on the car and made a huge difference. The hills in the south of France seemed to make mine worse, the heating and cooling. 2018 Telsa MS
Fri Sep 15 2017 7:34am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8847 |
Tyre pressures, wheel balancing and suspension alignment will all have an effect too.
Fri Sep 15 2017 10:08am |
Reading the OP - only the passenger side front lower arm replaced?
Fri Sep 15 2017 11:55am |
DuncanM2017 Member Since: 14 Sep 2017 Location: Lancashire Posts: 5 |
Yes, only passenger side as the garage said that was the only one that was fooked! I shall get it changed ASAP then is there a major difference between OE arms and the genuine LR ones? I've been told to stick to genuine LR for the arms?
Fri Sep 15 2017 1:19pm |
Re the arms; best keep them both the same so if genuine was fitted to the nearside then go with same on the offside. There is a lot of love for the Lemforder arms that Advanced Factors supply but I've not used them myself.
Fri Sep 15 2017 2:03pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 919 |
You seem to have done a lot of work on the front brakes etc but nothing at the back. Just picked mine up today after the parking brake sized on the morning we were going on holiday!. They couldn't get the discs off,, even after cutting the cables, just cost me for new module, new rear discs, shoes / pads etc. They did say calipers were sticking but they managed to clean them up and free them off. I did mention that I had been getting vibration under breaking,,, this might have been a factor. Was also recommended to take rear discs off and clean properly at each service as apparently they get so dirty they size which is half the cause of parking brake issues 2010 RRS, TDV8
Fri Sep 15 2017 2:05pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
I specifically get rear discs removed and park brake shoes cleaned out on every service Visitor from fullfatrr.com
Fri Sep 15 2017 3:06pm |
