Home > Maintenance & Modifications > Petrol engine additives
ceg1805
United Kingdom 2007 Range Rover Sport 4.4 V8 HSE Sumatra Black
Hi All,
Fairly new to the RRS game and wanted some advice on any cleaning/additives on a 4.4 petrol. Does anyone use anything regularly/as a one off? The car we've bought has done very low mileage with quite a lot of standing. I've had the throttle body replaced (by the dealer) when we bought it and he recommended.
Thanks very much,
Chris
Post #534506 Mon Sep 04 2017 12:37pm
Sorry not very clear, Google SSM46917 you should find it.
Post #534507 Mon Sep 04 2017 12:49pm
ceg1805
Brilliant thanks very much indeed.
Chris
Post #534509 Mon Sep 04 2017 1:03pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Petrol Engine Additives
I use the following products in my 2005 Honda Civic Vi Hatch
1) Liqui Moly Engine Detox - Every Oil Change
2) Liqui Moly Petrol Injector Cleaner - Every Tankfull of Fuel
I have owned the car from new and apart from regular oil changes the only items ever replaced in the 12 years of ownership are:
1) Battery at year 11
2) Front brake pads this year
I do an oil and filter change every 6 months. I use Mobil 1 oil. The Liqui Moly Engine Detox is added to a warm engine just before the oil change. You let it idle for 10 minutes with the product added.
I have done an oil change with and without the Liqui Moly Engine Detox, without, the oil that drains is fairly clean, with, it comes out very black.
I do my own servicing and the inside of the engine is spotless even in the combustion chambers.
The car only does short trips and low km's so it is a prime conditate for sludge build up in the engine and blocked injectors. The idle is very smooth and it drives like new and engine compression is excellent.
I must be doing something right.
Post #534744 Thu Sep 07 2017 6:02pm
What colour is the detox product ?
Post #534760 Thu Sep 07 2017 8:24pm
Meiang
The Liqui Moly Engine Detox is a clear fluid
Post #534783 Fri Sep 08 2017 5:53am
