Home > In Car Electronics > denso touch screen
rostan242@gmail.com
denso touch screen
anyone know what they are 3 plugs, I think this is a video in??
And what kind of plugs it is
Post #531809 Mon Jul 31 2017 11:44pm
They are called Fakra Connectors and they are colour matched i.e Brown will only fit Brown, however there is one colour which is universal and will fit all colours, it is a sort of blue/green probably called Aqua but that is a guess.
I can't remember offhand but I think the green plug is the one I used for Video Input for like a reversing camera. I really can't remember the exact definition of the other two, may have been for venture cam but not sure.
If you go to the Disco 3 site I think you will find loads of info. on them there.
Post #531812 Tue Aug 01 2017 3:02am
rostan242@gmail.com
Thanks for the reply
I just wanted to confirm that there is a video in, And I could connect the reverse camera, I have already ordered
Fakra to RCA Video Input Adaptor
Post #531817 Tue Aug 01 2017 8:28am
Bodsy
Site Sponsor
It won't work as a reverse camera unless you cut the middle touchscreen cable to make it think it's a Range Rover. And you need to have reverse camera enabled in car CCf.
You can of course manually put the camera on in diagnostics screen, but that's a phaff every time you want to reverse. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #531818 Tue Aug 01 2017 9:04am
When I did mine I did use a GVIF unit as I also fitted a TV Tuner and the Rear Entertainment/DVD etc. on to the front screen as well, which I guess would explain why I never had to modify the screen at all.
Post #531821 Tue Aug 01 2017 9:58am
rostan242@gmail.com
It was just my idea of what to pay for "gvif" since it can be checked at low cost. 9-pound adapter
And with the activation in the hidden menu is not a problem.
Maybe I'm wrong but it's probably worth a try
Post #531826 Tue Aug 01 2017 10:25am
Bodsy
Site Sponsor
You'll soon get Censored off with having to spend 20 seconds getting to the secret menu every time you want to reverse. Thumbs Up Bodsys Brake Bible
See it HERE
Post #531844 Tue Aug 01 2017 1:22pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
