Home > Technical > 2009 3.0 TDV6 engine fault |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Has it recently has the cam belt and HPFP belt replaced?
Mon Jul 10 2017 9:56pm |
Stretch Member Since: 10 Jul 2017 Location: Scotland Posts: 14 |
Yeah, at only 10k since a new engine i haven't stripped it down to inspect but as it's fine once settled im taking the timing as being ok. |
Mon Jul 10 2017 10:06pm |
Hi all,
Sat Jul 15 2017 4:52pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
I think if it was my car I would drop it off with Mikey, he is only about 50 or 60 miles away from you. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Jul 16 2017 9:19am |
Were they new Or used injectors? |
Sun Jul 16 2017 11:06am |
Used, they came out of a Disco 4 same year same engine with lower mileage (that i had access too )
Mon Jul 17 2017 7:45am |
Sometimes it's the simple things!
Wed Jul 19 2017 12:38pm |
What fault code reader is being used? Sometimes, the cheaper generic ones don't pick up all the manufacturer specific codes |
Wed Jul 19 2017 1:04pm |
My own Snap on machine running the latest software, Ive scanned it with an Autel though too and that showed nothing. |
Wed Jul 19 2017 6:47pm |
I'd be inclined to have it on an IID/Autologic/SDD, just to confirm it's not a manufacturers code not being detected |
Wed Jul 19 2017 8:19pm |
It's been on a Land Rover dealership machine, they picked up nothing. Sat in the dealership for 14 days then turned round and said the injectors needed coding Funny that as still doesn't run right after "coding" |
Wed Jul 19 2017 8:52pm |
