Home > Maintenance & Modifications > how to remove butterfly valve? |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
I did it on my RRS. It was very tight on the shaft and wouldn't budge at first. I sprayed penetrating oil on it and applied quite a force and it came free. Like you I was worried about breaking something but it all went well in the end. |
Sun Jul 02 2017 7:55pm |
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 77 |
cheers Phillh
Sun Jul 02 2017 8:52pm |
I used a large flat bladed screwdriver and placed a flat chisel under it when levering the butterfly off to reduce chances of damaging the unit itself. |
Sun Jul 02 2017 8:56pm |
You reply makes me question if I'm understanding this wrong... Did you lever the actual butterfly off of the spindle in situ? Or did you lever the spindle end out of the casing and then remove the butterfly?
Sun Jul 02 2017 9:00pm |
I levered the butterfly off the spindle. I just had a look at mine (I took it off 8 months ago and kept it in case I need to refit it for an mot or something) and there are 2 sleeves on the butterfly with a gap in the middle. If the screwdriver doesn't work, try levering the inner edge of the sleeve against the end of the shaft with a pair of pliars or grips. It will come off |
Sun Jul 02 2017 9:14pm |
So you can pull the butterfly off the spindle without pulling the spindle out of the housing? |
Sun Jul 02 2017 9:29pm |
No, you need to pull the spindle out. Bodsys Brake Bible
Sun Jul 02 2017 9:43pm |
Thanks Bodsy. I thought so, I must have misunderstood Phillh's post. I guess I'll try some grips on the spindle end to pull it out as levering it isn't budging |
Sun Jul 02 2017 10:08pm |
Finally got it with mole grips. Damn that thing wouldn't budge! |
Mon Jul 03 2017 12:41pm |
