Home > Faults & Fixes > Another Air con question |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
The pressure sensor reads the high side of the system
Fri Jun 23 2017 6:50am |
Hocks172 Member Since: 01 Dec 2016 Location: Brighton Posts: 83 |
Thanks godivanige I will check these tonight and report back with what I've found, appreciate your knowledge. Tesla model 3 long range
Fri Jun 23 2017 7:42am |
Hi here are the live values, these are about 3 minutes after a restart from a 20 minute drive, thanks Sam.
Fri Jun 23 2017 6:48pm |
Did you clear any outstanding faults prior to taking these readings and if so, did the pressure fault immediately reappear? 4.8 bar as a static pressure (I.e. Equalised system pressure with the compressor not running) is perfectly fine.
Fri Jun 23 2017 7:14pm |
Hi, there were no faults listed as i cleared them last night whilst trying to figure out what was wrong and they haven't reappeared? All seems very strange then if the values are correct is there a relay? or anything trivial it could be?
Fri Jun 23 2017 7:22pm |
Check the compressor is turning, with the clutch energised, you should see the centre part of the clutch spinning. If it isn't energised, the pulley around the clutch will be turning with the belts but the centre will be stationary. The clutch is powered by a relay. It's a little awkward to see on a V8, a torch and a mirror will help. Be careful of the fan/belts
Fri Jun 23 2017 7:38pm |
A colleague had a very similar problem to this, and dealer changed the Compressor and it's been fine since. Mind you even if it was also/or a sensor would they tell you?
Fri Jun 23 2017 7:40pm |
@ godivanige Thanks very much i'll check tomorrow as I'm currently watching my daughter swim, any ideas where about it is or is it a case of following the pipes? i take it somewhere on the auxiliary belt.
Fri Jun 23 2017 7:42pm |
Looking into the engine bay, it's on the right just under the power steering pump.
Fri Jun 23 2017 7:50pm |
Thank you very much for that picture i had been looking at the dynamic response pump Tesla model 3 long range
Sat Jun 24 2017 8:33am |
Right by looking at the compressor the outside is spinning but the inside is not?
Mon Jun 26 2017 8:52pm |
Hi Sam
Mon Jun 26 2017 11:21pm |
Hi Nige, thanks very much for the advise, sorry its took a while to respond. I've had a look at the wiring that all look intact where i can see it.
Tue Jul 18 2017 6:39pm |
Tue Jul 18 2017 6:40pm |
