Home > Maintenance & Modifications > Belt replacements |
Morgi27 Member Since: 31 Jan 2015 Location: Birmingham Posts: 88 |
It's a sport 2006 2.7 td coming upto 72k miles |
Tue Jun 13 2017 3:36pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Well the alternator belt has to come off to replace the front timing belt, so you may as well renew that. It drives the alt and the air con compressor. The fuel pump is driven by a belt at the rear of the engine, which should really be changed at the same time. It is a bit of a cow to do, because of the limited access. If that belt fails, no damage will ensue, but the engine will definitely stop!
Wed Jun 14 2017 9:33am |
